How can I use AirPlay with Android TV?
I’m trying to mirror my iPhone screen to my Android TV using AirPlay, but it’s not working. The TV isn’t showing up as an option when I try to connect. Does anyone know how to make this work? Really need assistance with this.
Android TVs typically don’t support AirPlay natively. That’s why your TV isn’t showing up. What you need is a third-party app to bridge the gap between your iPhone and Android TV. One highly recommended option is the Docast screen mirroring app. It’s designed to facilitate screen mirroring between different devices, including iPhones and Android TVs.
To get started, follow these steps:
  1. Install Docast: Download and install the Docast screen mirroring app on your Android TV. You can find it in the Google Play Store.
  2. Connect to the same Wi-Fi: Ensure both your iPhone and Android TV are connected to the same Wi-Fi network. This step is crucial for the devices to communicate.
  3. Open the App: Launch the Docast app on your Android TV.
  4. Enable AirPlay: On your iPhone, open Control Center and select “Screen Mirroring.” Docast should appear as an option.
  5. Select your TV: Choose your Android TV from the list, and your iPhone screen should start mirroring to your Android TV instantly.
If that doesn’t work, double-check that both devices are on the same network, and try restarting both the TV and iPhone.
For more information and to download the app, visit the official Docast app website.
I get what you’re saying, but you might also want to explore alternative apps. Sometimes it’s a matter of finding the right one that suits your specific setup. Here’s another approach:
  1. AirScreen: Consider downloading the AirScreen app. It works great with AirPlay and supports Android TVs. You can find it in the Google Play Store.
  2. Wi-Fi Connection: Make sure your iPhone and Android TV are on the same Wi-Fi network. This is non-negotiable for any screen mirroring to work.
  3. Launch AirScreen: Open the AirScreen app on your Android TV. It should automatically start setting up.
  4. Activate AirPlay: On your iPhone, go to the Control Center and pick “Screen Mirroring.” Your Android TV should show up listed as “AS-[Device name]” if all’s set up correctly.
  5. Select and Mirror: Choose your device from the list to start mirroring your iPhone screen to your Android TV.
If you find that Docast and AirScreen aren’t doing it for you, next steps could involve looking into any firmware updates for your TV or even exploring hardware solutions like an Apple TV. However, this should get you up and running for most common needs.
For those who are curious about Docast, make sure to check out the screen mirroring solution, which can streamline the experience for many setups.
Happy casting! :smile:
The methods shared by @mike34 and @hoshikuzu are solid, but here’s another angle you might want to consider. Some folks have found success with apps like ApowerMirror and LetsView as alternatives. These options can also be helpful if you run into issues with Docast or AirScreen.
Pros for Docast Screen Mirroring App:
  • User-Friendly Interface: Quite intuitive, making it easy to set up even for beginners.
  • Versatile Device Compatibility: Works well across different ecosystems, including iOS and Android.
  • Stable Connection: Generally reliable for steady mirroring with minimal lag.
Cons for Docast Screen Mirroring App:
  • Occasional Connectivity Issues: Some users report sporadic disconnects.
  • Limited Free Features: You might find certain features restricted in the free version, pushing you toward a paid upgrade.
  • Setup Time: While not overly complicated, it might take longer for some users compared to other apps.
For a quick wrap, if Docast and AirScreen aren’t doing it for you, ApowerMirror and LetsView are worth a look. They are also available on Google Play and support similar functionalities. Keep in mind, though, several users have reported that different setups work better with different mirroring apps, so some trial and error might be necessary. Also, ensure your network is stable; even the best apps struggle with spotty Wi-Fi.
For deep troubleshooting, firmware updates on your TV, or resorting to an external streaming device like Apple TV might be warranted if all else fails.
Happy mirroring!
