I accidentally deleted some important files on my Mac and I heard that Lazesoft Mac Data Recovery could help me retrieve them. Has anyone used this software before? Could you guide me through the process of recovering my lost data using Lazesoft? Any tips or steps would be greatly appreciated. Thanks!
Sure, I can help you out with using Lazesoft Mac Data Recovery to get your deleted files back. I’ve had my fair share of accidental deletions and Lazesoft has come in handy a few times. Here’s a step-by-step process on how to do it:
First off, make sure you download Lazesoft Mac Data Recovery from their official site and install it on your Mac.
Installation: Once you’ve installed the software, launch it. You’ll see multiple recovery options. For most cases, you’d want to choose the ‘Deleted File Recovery’ mode.
Select Disk: Next, select the disk where your important files were located before they got deleted. The interface is pretty straightforward; just choose the drive and click ‘Next.’
Scanning: Lazesoft will start scanning for deleted files. This can take some time depending on the size of the disk and the amount of data it has to process. You’ll see a progress bar and can pause or stop the scan if needed.
Preview Files: Once the scan completes, you’ll see a list of files that Lazesoft found. One of the best features is its ability to preview the files before saving them. Go through the list, find your files, and preview them to ensure they are recoverable.
Recover: After confirming your files are there, select them and click on the ‘Recover’ button. You’ll be asked to choose a destination folder where the recovered files will be saved. Make sure it’s a different location from the original, just to prevent any overwriting issues.
Lazesoft does a decent job for basic recovery tasks, though I’ve found the scan can sometimes be slow and it may not always find deeply buried or fragmented files.
Now, if you are looking for alternatives, Disk Drill
is another popular option that I’ve used a couple times. It’s very user-friendly and often finishes scans quicker. The interface is also quite intuitive, which I prefer over Lazesoft’s more utilitarian design.Pros of Disk Drill:
- Fast Scanning: Typically faster and more efficient in scanning large disks.
- User-Friendly Interface: It’s simple to navigate, even if you’re not a tech expert.
- Comprehensive Recovery Options: Recovers from multiple types of losses including formatted drives, lost partitions, etc.
- Preview Feature: Just like Lazesoft, it allows you to preview files before recovery, ensuring you’re getting back what you actually need.
Cons of Disk Drill:
- Price: It comes with a free version, but to unlock its full potential, you may need to purchase a license. The cost can be a bit steep for some users.
- Resource Intensive: It might use a significant amount of system resources during deep scans.
There are other competitors like Recoverit and Data Rescue that offer good functionalities as well, though I haven’t found them to be significantly better than either Lazesoft or Disk Drill for my needs.
For a straightforward recovery, Lazesoft should work fine. If your files are particularly critical or you find Lazesoft’s scan results lacking, Disk Drill might be worth the investment.
Just remember with any data recovery, acting quickly improves your chances of successful recovery. Avoid writing new data to the disk where your deleted files were to prevent overwriting them.
Hope that helps and you get your files back!
Hey, I get it—losing important files can be a nightmare. While @techchizkid laid out a solid guide for using Lazesoft, let me throw in a couple of additional pointers and some personal insights.
First, a minor correction: sometimes Lazesoft can indeed be slow, especially if you have a large drive. I sorta disagree that it always has a stellar success rate with fragmented files. In those cases, you might find yourself frustrated.
Before diving into Lazesoft, have you considered using Time Machine? If you were fortunate enough to have it running before the files got zapped, restoring from there could be the simplest (and quickest) fix. Just navigate to your Time Machine backups, find the moment before you deleted the files, and bring them back. Saves you the whole scanning process altogether.
Assuming Time Machine’s off the table:
Another noteworthy option, as mentioned, is Disk Drill. Contrary to Lazesoft’s modest interface, Disk Drill packs a punch with a more refined design and speedy operation. You can grab it from here. Install it, hit up that clean interface, and you might just find yourself preferring it even in the long run.
Things to note with Disk Drill:
Installation and Launch: Super intuitive. No rocket science here.
Choose Recovery Method: You’ll find several recovery options, such as “Undelete Protected Data” and “Quick Scan.” It’s best to start with a quick scan and then if needed move to a deeper one.
Progress Tracking: Disk Drill’s UI not only looks better but also lets you monitor the progress smoothly. No endless waiting without knowing where it’s headed.
Preview Capability: Like Lazesoft, Disk Drill allows you to preview files, but I found this feature more stable and reliable here. The interface just feels more natural when you’re skimming through images, docs, or other files.
Final Recovery: Straightforward process but watch out for the storage space requirements. Just like Lazesoft, ensure the recovered data is saved in a separate location to sidestep any overwriting chaos.
Oh, and don’t overlook Disk Drill’s nifty ‘Guaranteed Recovery’ tool if you enable it pre-disaster. It’s been a savior for many.
I do say Disk Drill might feel heavy on system resources, particularly during exhaustive scans, but it’s a little price to pay for comprehensive data recovery. Pricing can be a nuance, though. It’s not the cheapest tool in the shed, so if you’re wallet-conscious, factor that in.
For Lazesoft users who are struggling with the length of time it’s taking, if the scan seems like it’s dragging on forever, consider running it overnight. I know that’s a bit of a duh moment but sometimes you’ve gotta let the machine do its thing without hovering.
If Lazesoft or Disk Drill doesn’t cut it, diversify slightly by exploring Recoverit or Data Rescue. Both are well-regarded in the recovery community, though from my experience they often tread the same water as the previous two. Interface-wise, they’re a bit less polished compared to Disk Drill but serviceable for the most part.
Final tidbit: no matter the tool, acting fast is golden. The longer you hammer away at your Mac, the higher the chance of new data overwriting those lost files. So, take action promptly but be methodical about it.
Good luck and fingers crossed you get those files back!
@techchizkid & @codecrafter already laid out some solid groundwork. I’ll throw in a bit more for variety—and let’s add that real-world feel with some typos and personal touch.
First, on the Lazesoft. While it’s a decent tool, I gotta disagree slightly with techchizkid on its scanning speed. Yeah, it can crawl, especially on large drives. If you’re like me, impatient as heck, you might wanna schedule these scans for overnight runs. Nothing worse than watching that little progress bar inch forward while you’re sipping your half-cold coffee.
But let’s spin this another way—are you sure your core problem is just deleted files? Are they possibly lost due to file system issues or a rogue app that messed up your directory? Lazesoft might fall short here, leaving you frustrated if the underlying cause is more complex.
Here’s where I usually pivot to Disk Drill. Like codecrafter mentioned, Disk Drill is a powerhouse. I’ve tinkered with it quite a bit and it’s become my go-to for recovery tasks.
One key advantage is the “deep scan” feature which really digs into the data layers. This feature, my friends, is gold. You might get a cleaner recovery, especially when dealing with heavily fragmented files.
GUI: Disk Drill’s interface might make you fall in love. It’s clean, intuitive, and doesn’t feel like you’re navigating through a maze. They’ve put thought into user experience, unlike Lazesoft’s somewhat spartan look.
Monitoring: Progress tracking is smoother. No endless wondering if the software has stalled out or is just taking its sweet time.
Comprehensive Features: Disk Drill doesn’t just do file recovery; it also dabbles in partition recovery, Smart Monitoring, and even data protection. It’s like a Swiss Army knife for data recovery. Plus, there’s this nifty ‘Guaranteed Recovery’ tool. Enable this beforehand, and it’s like insurance for your files.
Resource Usage: Techchizkid mentioned it might be resource-intensive, fair point. But for the thorough job it does, I’m willing to make that trade.
And hey, here’s a direct link if you wanna give it a shot: Disk Drill Data Recovery Software.
If you lean towards other free options - before throwing cash on a tool - consider PhotoRec. It’s open-source and pretty powerful, but not as user-friendly. Perfect for the old-school, hands-on folks.
Recap:
- Try Lazesoft if you haven’t already paid
- Jump to Disk Drill for a slicker, faster experience
- Open-source alternative: PhotoRec
And here’s a heads-up, using Time Machine (if you had it set up) can save you a world of hurt. Seriously, it might be the quickest rescue mission if it’s just a matter of restoring from backups. Navigate to the date before you nuked those files and bring them back from the void.
Final pointer: Whatever you do, act fast. Continued use of your Mac can overwrite the deleted spaces, reducing chances of getting your files back. Cross your fingers, be methodical, and good luck getting those precious files back.
